Thread
1986 CRX VX Failed Smog
04-10-2014, 11:06 PM
10
permalink
wagonef8
Del Slow
- '94 Honda Del Sol Vx
90 day:
42.31
mpg (US)
Retard your timing run 1/3 E85 to gas and make sure you do a tune up ..you can check for vacuum leaks use break part cleaner spray around manifold if you have a leak your idle will change when you spray good luck
wagonef8
View Public Profile
Send a private message to wagonef8
Find More Posts by wagonef8
