Old 04-11-2014, 02:39 AM   #7 (permalink)
94-turbo
In case anyone is looking for mpguino deffinitions
1. "Custom":
| MG Instant MPG | S Instant Speed |
| GH Instant GPH | C Current MPG |
2. "Instant/Current":
| IM Instant MPG | S Instant Speed |
| CM Current MPG | D Current Miles |
3. "Instant/Tank":
| TM Tank MPG | D Tank Miles |
4. "BIG Instant":
| Instant MPG |
5. "BIG Current":
| Current MPG |
6. "BIG Tank:":
| Tank MPG |
7. "Current":
| MH Current MPH | MG Current MPG |
| MI Current Miles | GA Current Gallons |
8. "Tank":
| MH Tank MPH | MG Tank MPG |
| MI Tank Miles | GA Tank Gallons |
9. "EOC mi/Idle gal":
| CE Current EOC Miles | G Current Idle Gallons |
| TE Tank EOC Miles | G Tank Idle Gallons |
10. "CPU Monitor":
| C% Max %CPU utilization | T Tank run time |
| Free Memory (bytes) |
Modifications for metric mode:
Custom screen:
MG->LK (Miles Per Gallon -> Liters per 100KM)
GH->LH (Gallons Per Hour => Litres per Hour)
Combo Screens:
IM->IL (Instant MPG -> Instant L/100KM)
CM->CL (Current MPG -> Current L/100KM)
TM->TL (Tank MPG -> Tank L/100KM)
Big number screens:
MPG->L/K (MPG -> L/100KM)
Trip screens:
MH->KH (Miles Per Hour -> KM per Hour)
MI->KM (Miles -> KiloMeters)
GA-> L (Gallons -> Liters)
EOC/Idle screen:
G-> L (Gallons -> Liters)
There is also a setup screen that displays the first time the program is run and by pressing all three buttons at once. It walks you through the following setup variables. Use left and right buttons to select the digit you wish to change or the OK or Cancel (XX) items. Use middle button to rotate the current digit or select OK or XX if that is where the cursor is. Selecting OK will save the currently displayed value to the current variable and advance to the next variable. Selecting XX will just advance to the next variable.
Contrast - This comes up first on a brand new run and changes on the screen are immediate so if you can't see anything try pressing middle button a few times.
VSS Pulses/Mile - use this to adjust displayed speed/miles. If the speed/miles displayed on the mpguino is low then decrease this number by the percentage that it is off and vice versa for high readings. Most asian cars will be a multiple of 8204 and GM will be 10000, we are hoping users will contribute model specific data here. (Note: Later versions of the code have a setting for VSS Debounce, default is 2 mSec. With high VSS values, this needs to be set to 1 or zero)
MicroSec/Gallon - use this to adjust displayed fuel consumption. You may want to readjust this initially to get a ballpark MPG reading (after VSS Pulses/Mile is deemed accurate), then calibrate it with a couple fillups. If the mpguino displayed MPG is high or the displayed tank gallons is low at fillup then reduce MicroSec/Gallon by the percentage that the gallons are low or the displayed mpg is high. Like the vss pulses, this would benefit from user contributions about what values work for what specific cars.
Pulses/2 revs - not currently used, but a single injector on a 4 cylinder sequential system will make 1 squirt in 2 revolutions. Hope to be able to base RPM on this at some point.
Timout(microSec) - defaults to 7 minutes. If there are no injector or speed signals from the car and no buttons are pressed in that time then the display backlight turns off. When activity resumes the display will turn back on and the current trip will reset and the tank trip will be restored to the point of last activity.
Tank Gal * 1000 - not currently used, but defaults to 13300 or 13.3 gallons.
Injector DelayuS - Represents the mechanical delay of the injector in microseconds. Advanced topic.
The Following User Says Thank You to 94-turbo For This Useful Post:
deejaaa (04-12-2014)
