Old 04-11-2014, 08:13 AM   #43 (permalink)
stoatwblr
Originally Posted by ksa8907 View Post
Not true ever and at all. Back pressure is a myth. Ideally you want a properly sized exhaust so that the flow(speed too) of the gases will assist in pulling exhaust through the system. I agree with your explanation, but back pressure is a no go, there may be pressure build up(i know there is) but it's not a desired effect.
You're quite right. It's a combination of inertia of the exhaust flow pulling gass through and impulse reflection management, but it's a useful myth to hold on to for general rule of thumb work.
There's also some benefit in ensuring that gases "swirl" or rotate down the pipes instead of trying to have laminar flow, but that kind of mod is well out of the range of simple "knock it up and see how it goes".
