Old 04-11-2014, 07:48 PM   #6458 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
I"m thinking a couple 0000 lugs sticking out of the end cap for attaching to B+ and B-. Then, how I connect it all inside to the capacitor is pretty irrelevant to the outside world. I need me a 0000 lug crimper. Actually, I may be able to make one with some big cable cutters I have and an angle grinder. I already turned it into a 2 gauge crimper, now I just need to grind the hole a little bigger. Or a small piece of bus bar might be good. Oh the possibilities are endless.
My two cents:
Keep it simple. Just run the 2gauge where it needs to go in the controller and lets us worry about hooking the other ends up. Each extra connection in the power path is an additional voltage drop and potential failure point.
The Following User Says Thank You to jedsmd For This Useful Post:
MPaulHolmes (04-11-2014)
