Old 04-12-2014, 08:42 PM   #258 (permalink)
user removed
Some more pictures. Floor is basically finished, need some more tabs welded to the frame to mount the floor pan securely. Perfectly flat from bow to stern . Only thing protruding are the screw heads. Motor is temporarily secured with all of the necessary components to get it running. I need to make a bracket to hold the fuel tank, radiator, and the EFI components in place above the engine. I'm not going to securely mount the engine until I get the rear sprocket configured with the Harley wheel, so Ican make sure the chain is properly aligned before I drill the mounting holes for the engine support brackets.
regards
Mech
ID:	14866   Click image for larger version
ID:	14867   Click image for larger version
christofoo (04-23-2014)
