Old 04-13-2014, 03:40 PM   #45 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by YeahPete View Post
Can you do a write-up on how you did those mirror covers? They look slick.
Unfortunately, I didn't get any pictures, but the process was very easy, especially compared to my old car (where I had to cut the mirrors off their bases, fiberglass over the hole and attach the plastic piece with the threaded rods so I could attach it back to the car). On the Prius, there are three bolts that thread from the inside of the door into the mirror base, a rubber gasket, and the mirror itself. Simply remove the mirror by undoing the bolts, trace the outline of the gasket onto a piece of aluminum, attach the bolts through the gasket to nuts with lock washers, and silicon the aluminum plate to the rubber gasket.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
COcyclist (04-14-2020), j12piprius (12-14-2022)
