Old 04-14-2014, 03:39 AM   #4 (permalink)
Davo53209@yahoo.com
Originally Posted by cbaber View Post
I don't think a simple gasket replacement would cause this issue. But it's possible something was dropped into the head. The torque of the VC bolts isn't critical if you are not getting leaks, it's probably not an issue (i've never used a torque wrench on them). Could it be that you just now noticed the ticking while working in that area?
I would level out the car, check the oil level, and try it again. If it doesn't go away grab your feeler gauges, a service manual, and inspect the valve adjustments.
No I was meticulous with regards to preventing anything from dropping into the head; but now that you mention it, I probably could use a good oil change and at most, a valve adjustment. Like you've suggested, I will level out the car and run some new oil first. If that doesn't work, I will then do the valve adjustment.
Thank You.
