You Know You Are An Eco Modder if....you see this and can turn it into thought experiment other than poor guy lost his rear window.
The fact that it is a high pressure back there (bag pushed in) is a good sign of attachment. With bad aero you usually get low pressure at the back which would pull the bag out. Also kind of depends on if he had windows up or down and if he had cabin fan on or not too.
