Old 04-14-2014, 11:04 PM   #6 (permalink)
nickeastwood
Sounds light higher compression may be the only way to be able to get my gearing taller. Right now the bike is geared about as tall as it could possibly pull. I don't see how a less restrictive exhaust and filter would help. I'm used to working on small two stroke bikes so this is all fairly new to me. Also I have adjusted the valves cleaned and gapped points and set valves. It's running as good as it possibly can at the moment
