Old 04-15-2014, 12:11 AM   #16 (permalink)
TurnNBurn
Originally Posted by mechman600 View Post
That's not what I said. An Arduino will work great. The amount of resolution you desire will determine how many Arduino boards you will need. A single Arduino with a Mux Shield will give you a 0.1V resolution on a 72V car and three will give you a 0.035V resolution. Not difficult to set up. I am going to change my tune and say that even 0.1V resolution is good enough, especially if you keep it conservative and don't try to charge/discharge to the limits.
Ok. I must have misinterpreted when I read the "muxshield probably won't work" and lost hopes.
What sort of items would I be looking for to compile a shopping list for an Arduino setup? Is there any soldering required?
