Originally Posted by MPaulHolmes
OK now I need help finding a terminal block that has 10 positions. Maybe screws on the inside, so the screw head clamps a u shaped terminal attached to the wire, and similar for the outside. Is that confusing?! All the terminal blocks I've found only show one side, and I have no idea what's on the other side! anger! Or they just sandwich a wire down by screwing a screw, but I've found those to be very unreliable with stranded wire. It comes loose all the time on my milling machine setup.
Or I could solder one side, and just a screw terminal on the other side. Oh the humanity!
EDIT: NEVER MIND!!! I found something I think will be OK.
Paul,
How about something like this. Cheap (<$5) and easy to mount.
10 PIN Aviation Amphenol Cable Connector Plug 19mm 20mm | eBay
