Thread: Nitrogen tires
Old 04-16-2014, 09:57 AM   #108 (permalink)
niky
Since oxygen permeates much faster, the simple way to get 92% Nitrogen is to fill to 50 psi and let the oxygen permeate out:
http://www.nhtsa.gov/DOT/NHTSA/NRD/M...094.pdf‎
if a normally maintained in-service tire is not punc*tured or deflated, the faster diffusion/consumption of oxygen relative to the nitrogen content ofthe inflation gas results in an increase in the percentage of nitrogen gas from the original 78 per*cent to as high as the 91 percent observed, thus lowering the effective rate of inflation pressureloss.
They didn't use such high inflation pressures, but it's an interesting idea... considering many hypermilers use significantly higher than the 29 psi used in the field aging test.
Want 95% nitro? Keep filling with 60 psi, and eventually, you'll get there.
