Old 04-16-2014, 04:16 PM   #1 (permalink)
Mrtony5
Cruze - '12 chevy cruze eco
90 day: 34.45 mpg (US)
2003 Civic Hybrid EOC Kill Switch/Injector Cutoff simple how to
I looked all over for a diy of how to do a kill switch for a civic hybrid and couldn't find much. I finally found a wire diagram of the injector relays.
The Yellow/ Black wire is the ground for the injector relay number 1 which is a brown relay on my car, that is the one I installed a switched off.
Materials list:
Momentary switch normally closed
Wire (14 gauge)
Wire connectors
Misc ties-tapes
How to:
Locate the relay bank which is behind the glove box
remove the kick panel under the glove box
Lower the relay bank by pushing the lever and lifting the bank up and out
Cut the yellow/black wire
Splice in the wire for the switch
Run the wire to the gear shift or where ever you want to mount it
And enjoy.
Only my second DIY Tread so don't hate.
Any positive input is greatly appreciated
Pictures speak a thousand words see below
ID:	14889   Click image for larger version
ID:	14890   Click image for larger version
ID:	14891   Click image for larger version
ID:	14892   Click image for larger version
