Old 04-17-2014, 06:39 PM   #32 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
There are a ton of seadoo and skidoo owners who learned the hard way they can't even run E10. It's not just sitting with the gas, it's running it too. As said it leans it out a little but where it killed them is all the fuel lines are turned into green goo on the inside which ends up clogging the fuel filter. Then it really leans them out and they are dead in short order. This is also common on older outboards. Maybe you get by on a doggy Briggs motor but for high performance stuff I wouldn't run it unless you make adjustments and modifications for it.
