Did you disconnect the starter battery, wait 15 minutes, reconnect it and let the car idle for 15 minutes? Hondas "learn" a lot of stuff during operation and they can learn good as well as bad habits. Make sure you got your radio code if needed before doing this and presets. Dont worry if your ima shows empty, it also has to relearn its soc once reconnected.
