Old 04-18-2014, 08:39 AM   #23 (permalink)
Daox
Nah, its the older 2.2 before the ecotec.
Well, a few miles with a scangauge will tell you a lot!
1) 45 mph and locked trans is WAY better than 40 mph unlocked. We're talking ~15% increase in FE. This just reinforces the thought that locking the trans is super important.
2) The trans will stay locked at engine loads up to at least 80%. This means accelerating with the trans locked is totally doable. Clutches care about torque, not horsepower.
3) It actually runs about 210F when fully warmed up. I might want to look into this to see if there are any issues. This seems very warm. I want to make sure the radiator fan isn't kicking on a ton to keep things cool.
4) Neutral idle consumption is about .36 gph. Keeping it in drive while not moving is .39 gph. So, there is about an 8% fuel consumption reduction from shifting to neutral at stop lights.
5) P&G with neutral coasting at in town speeds 25-35 mph is effective.
6) Its still not that easy to top out a heck of a lot more than 30 mpg.
Mpg in to work this morning was 31.6 mpg, a significant jump (thank you scangauge!) since yesterday (27.2) with nearly identical weather. Ambient temps were mid 30F.
The Following 2 Users Say Thank You to Daox For This Useful Post:
Insight for life (04-18-2014), pgfpro (04-21-2014)
