Old 04-18-2014, 11:09 AM   #27 (permalink)
duckwize
Originally Posted by Cobb View Post
Did you disconnect the starter battery, wait 15 minutes, reconnect it and let the car idle for 15 minutes? Hondas "learn" a lot of stuff during operation and they can learn good as well as bad habits. Make sure you got your radio code if needed before doing this and presets. Dont worry if your ima shows empty, it also has to relearn its soc once reconnected.
I didn't disconnect the battery and wait. The car did idle forever though. And I do have my code.
Like I said, it seems everything is on the up and up though, I'm quite happy with how its running. Sadly the 03 civic will probably never be back up to the 48+ mpg from normal driving. Though I am trying to get it as close as possible.
On a side note: I changed the 4 spark plugs last year (and they were needed). Yesterday I found out that there are another 4 hidden under the plastic engine cover. 2 of those 4 were worn fairly badly. I'm hoping with the new plugs that this will also help me get my fantasy MPG.
