Originally Posted by P-hack
(downloading coocox ide + prereqs)
Yah, I'm thinking that soldering and wiring are going to be challenging if you don't understand this stuff. And being all experimental when you are trying to protect your batteries could screw up something, do more harm than good.
You know how to measure voltage? That is the only skill needed for bottom balancing.
Yeah, I know how to measure voltage. I know how to use a multimeter to test voltages and resistance and things like that.
So you guys think if I don't have a BMS I should bottom balance once in a while and that'll be good? By once in a while I mean once every few months.
