Cool! FYI you have some synchronization bugs in your method 2. I prefer the method 2 approach as it has a controller in control that initiates communication so it can collate the results. Also fixed length binary data is easier to keep in sync than random length numbers as strings (and faster). Finally arrays make nice containers for lots of sensors, here is an example:
Code:
//example slave code
//hard code the first cell this slave is reading. (cell 1 is 0)
#define cellstart 8 //16 for the second slave
#define numcells 8 //2 for the second slave
void setup() {
Serial.begin(9600);
int readings [numcells];
void loop(){
for(int x = 0;x<numcells;x++)
for(int t=0;t<16;t++) //take several readings
readings[x]=analogRead(x);
if(Serial.available() > 0) {
int cell = Serial.read(); //inquiry sent by Master
//see if this board services the cell in question
if(cell >= cellstart && cell < cellstart + numcells){
Serial.write(lowByte(readings[cell-cellstart])); //send low byte first
Serial.write(highByte(readings[cell-cellstart])); //then hi byte
Code:
//master example
//model 2, with byte level communication and arrays/iteration
#define numcells 18
void setup() {
Serial.begin(9600);
int readings [numcells];//easier to deal with lots of values in an array and loop over them
void loop() {
for(int x = 0; x < 8;x++) //readings for cells 0-7 are "local"
for(int t = 0; t < 16;t++)
for(int x = 8; x < numcells; x++){
Serial.write(x); //send the cell number to the slaves
while(Serial.available() <2) {} //wait for two bytes of adc
readings[x] = Serial.read(); //load the low byte
readings[x] += Serial.read()<<8; // fill in the high byte
//... do something interesting with all those readings
//i.e. convert them to actual cell voltages and look for high and low
int basevolt=0;
for(int x = 0; x < numcells; x++){
int cellvolt=readings[x]-basevolt;
basevolt=basevolt+cellvolt;
// lcd.clear();
// lcd.goto((x%5)*4,x/20);
//lcd.print(cellvolt); //10 bit value of the cell voltage
delay(500); // wait for a second
note, you might want to shuffle the cell starts and the local loop so that you have some ADC ports on the master for current and temp and ?
