Old 04-19-2014, 01:11 PM   #1 (permalink)
Joggernot
Joggernot's Avatar
44 psi vs. 32 psi and costs
I did a spreadsheet on the cost of running 44 psi vs. running the recommended 32 psi. I have found that 44 psi wears my tires in the center and I need to replace tires sooner than the stated lifetime of my tires. The spreadsheet shows that even with an extra set of tires I come out ahead using the 44 psi tire pressure.
I had to drop the miles per set of tires down to 1/3 the stated lifetime of my tires before it was almost a break even. Has anyone else done this evaluation? What are your results?
The Following 3 Users Say Thank You to Joggernot For This Useful Post:
Piwoslaw (04-25-2014), redpoint5 (04-19-2014), SoobieOut (04-25-2014)
