Originally Posted by Blue Bomber
The high percentage of ethanol in E85 can destroy certain hoses and seals in your fuel system. At the minimum, you should replace your fuel lines with an E85-compatible material to prevent major leaks. Your fuel pump and injector O-rings may also need to be upgraded in order to ensure full compatibility.
Depends on the year of the vehicle. You guys running old stuff, maybe. But for some time the automakers have been designing for E10. A lot of the materials have already been "hardened" for the ethanol.
I think the biggest issue is will it throw a CEL, and is it really running lean or not? If you are going to go down this road, mix your E85 with gas so you don't get a CEL, or get a scangauge II to know what is really going on.
