Thread: slant back nose
Old 04-19-2014, 08:05 PM   #8 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
diy instructions
Reposting the instructions
by Aerohead
I left the car intact, and simply created a mockup of the mods out of cardboard and regular masking tape, after triple waxing the attachment areas with Meguire's 100% carnauba car wax.
Then I did wet layups of fiberglass cloth and polyester resin right over the mockups, both from The Home Depot paint department.
After 3-layers of cloth/resin and a good cure, I pried the parts off the car and tossed them into a stock tank from a local farm supply house (sometimes you see these at tire stores where they immerse leaky tires to locate leaks) to 'dissolve' the cardboard, leaving only the shell.
Some Bondo body filler and sanding (again from Home Depot) later, I used spray primer and top coats from AutoZone/O'Reileys, plus some 3M colored tape to simulate the HONDA trim.
An air compressor is handy for operating pneumatic air files and rotary sanders. An electric random-orbital sander and sanding blocks help dial in the final shape. A good respirator is a must for both dust and VOCs coming off the paints. Eye protection (I also hook a cheap HOOVER vacuum cleaner to my random-orbital to keep dust down). An air blower,then Detroit tack rags are good for final cleaning before primer and top coats. Use all the ventilation you can get.
I just drilled into the car for attachment using trim screws from an auto paint supply house. I used riv-nuts in existing holes when I could, for belly pan especially.
And a trailer light kit for the boat tail. It slips on and off like a glove also. Rocker panel extensions were fabbed up at a local sheetmetal company. The elliptical wing is 4-pcs of baseboard trim joined together back-to-back and glassed over. Plexiglass for the fenestrations. Lexan would be way better.
It's easier to do than talk about. You can't hurt anything and the learning curve is fast.
The Following User Says Thank You to j12piprius For This Useful Post:
aerohead (04-21-2014)
