Old 04-19-2014, 11:04 PM   #15 (permalink)
XYZ
Originally Posted by Ryland View Post
Gasoline does seem to last longer in a gas can or car gas tank then it does in a lawn mower or motorcycle gas tank, I suspect part of it is the more stable temperature and better seals.
You understand what I said about a vented fuel tank.
I have "fixed" countless motorcycles, mopeds, lawn mowers and snow blowers by replacing the "year old" gas.
I have fixed many lawnmowers, blowers, etc. with gunked-up carb reservoirs. The residue left from evaporated gas is like varnish. Once there is crud is in the carb, the engine ain't gonna run.
In motorcycle owners manuals they always say to store the motorcycle with either a full or an empty gas tank, never half way or worse 1/8 full because you have a lot of surface area for moisture to condense and a lot of air space for vapors to form and escape.
The same thing applies to all gas powered engines.
A friend of mine who owns a motorcycle shop once said that fuel injection will kill his business because the sealed fuel systems nearly eliminate fuel related issues.
He understands that. I do, and you do, too.
