Old 04-22-2014, 12:16 AM   #42 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by renault_megane_dci View Post
What do you use to stick the rear mods to the trunk ?
How well does it stick ?
Is it removable ?
cut it out as close as possible to the contour, used 100% silicone, white. sticks real well, i can use it to open/close the trunk(boot). removable only if i don't want to put it back on.
i plan to remove it tomorrow, just to see if there is any diff in mpg. have already removed the side pieces with no change.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
renault_megane_dci (04-22-2014)
