haaaaaaaaaaa.. I get it..
because: V = R * I and R is fixed and I varies V will also vary, and you calculated that 3 feet of 2 gauge wire is enough R to vary V enough at max I, right?
To make the picture complete.. where does this voltage drop occurs? Between the collector and the emitter of the IGBT?
