Old 04-24-2014, 07:42 AM   #198 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 42.21 mpg (US)
A: You are correct, those are temperature probe strips.
B: 1.2 volts is a "nominal" voltage. Normal operating voltage is significantly higher. If you are going to be using a Superbrain to cycle the subpacks you will see that it will charge them to over 9 volts (I don't remember exactly how much) before it considers them full.
