Welcome Jay-Rod, you can easily top 40 MPG with the fuel stingy Civic. Shifting the manual at the right time will make more difference than anything else you do. Keep the RPM's below 2200 when accelerating & run in the highest gear possible. You should be in 5th gear by 35 MPH most all of the time.
Good luck!!
