Old 04-24-2014, 10:29 AM   #14 (permalink)
oil pan 4
Another way to reduce brake drag is to replace the brake piston seal when you replace the pads.
This seal is like an o-ring, but instead of being round its got a square cross section profile. This square profile allows the seal to pull back the piston a tiny bit when the brakes are released.
I fear that with age the seal loses this ability.
The pad springs help the square o-ring do its job.
