Old 07-08-2008, 06:06 PM   #62 (permalink)
Magister
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
I am working on it alone for the moment (ISO only). I just received my freeduino kit, it's not soldered yet.
The code for the moment compile but is not tested, it's in the google project, code/trunk.
I soldered small wires on the MC and will solder them on a proto PCB, yep it's small!
I made a cable but if you know what to do, no problem with just tacking the signal from the wire before the plug.
Check also the wiki in the google project.
opengauge - Google Code
2013 Hyundai Sonata Hybrid
