Old 04-25-2014, 12:23 AM   #15 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
in my lupo i took out the old bearings. cleaned old grease out. installed redline bearing grease where i had mixed some ws2. i also left the nut little loose. i measured the effect by rising wheel in air and rotate it with your hands.
normal car which brakes arent dragging is 7-15s
if you have good stock setup is 15-25s
modified rear wheel bearings is 25 up to 65 seconds. you can feel the difference i would say. can you see it at the pump is another question. i try to get some results with the A8 project.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
