I've only seen even wear with mine at pressures *above* those mentioned here. I still see the edges wear down faster on the front if I don't rotate them. The worn edges sit high in the back until the middle is worn to match, then they wear evenly from there.
Three vehicles, 6 sets of tires, ~200k miles between them all. (2 sets were used when purchasing used vehicles). Tread wear I can't comment on since our "chip & seal" roads chew up everyone's tires prematurely regardless of pressure.
I do buy quality tires - Michelin, Goodyear, Yokohama.
![](http://ecomodder.com/forum/fe-graphs/sig268a.png)
