Originally Posted by Old Mechanic
Timken used to be the best you could get. Not so sure now. A bearing could be the cause of an alignment problem, but the alignment could be off due to an impact which could also cause the bad bearing. Typically bearings last a very long time.
regards
Mech
I didn't realize Timken produces bearings at first. It's ironic because I purchased Timken brand bearings/hubs for my Civic, and they come with NTN bearings installed in the hubs. The reason I recommended it was because Honda uses the same NTN bearing from the factory, but the factory parts cost 2x a much.
I guess Timken doesn't even trust their own bearings lol
