Old 04-26-2014, 05:11 AM   #92 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Old Tele man View Post
Yep, IMHO, only 4-manual gears are needed:
First, to get you moving.
Second, for urban driving.
Third, for highway driving.
Reverse, for going backward.
...of course, the above ASSUMES the proper/appropriate/correct gear ratios are being used.
That'd leave a pretty huge gearing gap in-between those driving conditions.
Fuel consumption dropped along with more gears, either manual or automatic, allowing the tops to be longer geared.
On the up! I can do 30 mph in 5th @ just above idle, level & steady, so I'd like to have a 6th to cut down rpm on the motorway or at higher speeds.
It's not that the gearing is badly chosen though, as it needs its gears to move about in a sort of half decent fashion.
0-60 is reportedly a solid 16 seconds (It feels a bit faster).
It'd be a real dog on 3 forward gears.
