Old 04-26-2014, 05:30 AM   #93 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by oldtamiyaphile View Post
Three close stacked overdrive gears! I only average 27km/h so it basically would have been a 3-4 speed for my normal use. I went with the more convervatively geared VW Transporter (~1000rpm at 60km/h).
3 overdrive gears let down by the short final drive, so revving too high for your regular use.
More gears would have helped it retain a good initial pull in low gears, often needed in heavily loaded vans, yet long geared for efficient highway use.
1000 rpm @ 60kph should be pretty efficient.
It's all about picking what suits one best.
The Following User Says Thank You to euromodder For This Useful Post:
NeilBlanchard (04-26-2014)
