I just read your post and it's very interesting. Have a question. I'm not sure if I understand or not, but is it possible to do a frame with no welding?
thanks
Originally Posted by CFECO
If you are going the tube frame route, you might look at composite tubing. There is "Pultruded" fiberglass tubing in many shapes, round, square, I-beam, flat, angle, etc., which can be stronger and lighter than steel or aluminum, plus no exotic welding skills are need to join the tubes.
