Old 04-27-2014, 02:36 PM   #74 (permalink)
redpoint5
90 day: 38.47 mpg (US)
You have a great idea to eliminate the batteries from under the bonnet. Using an ultracap would allow you to use a thinner gauge of wire to the batteries in the rear. The car should handle better having the weight more evenly distributed.
Failing this, buy a section of Mylar for insulation. It isn't conductive and does a great job at thermal insulation (and is dirt cheap).
I assume the TDI has glowplugs? If so, you could easily over-run the ability of the supercaps to supply them and then start the high compression motor.
