air dam
I think gutting is a good idea. Thank you. I've got to replace my front motor mount(maybe inserts all the way around) first before I can do anything. Motor has so much rock I can barely take off on a hill. As for the lawn edging, I was thinking something bigger like the plexiglass used on that 118mpg car. I did see where one guy had cut the top of a 2nd bumper off as a air splicer and then used some rubber as front wheel spats. Something along those lines if this plexiglass idea never sees daylight.
