Old 04-27-2014, 09:21 PM   #2 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
What's the exact code? After clearing it start the car. The CEL should not stay on. The CEL will come on for a couple seconds when you key it on. Which wire harness did you use? What ECU are you using? The CX did not have lean burn, so that ECU won't help you. Also, the EGR connections are different between the HX, VX, and JDM 3 stage.
1998 Honda Civic HX - My Project Thread
