Old 04-28-2014, 12:38 AM   #42 (permalink)
CFECO
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
The CVT would require custom fitting to adapt the motor. The golf cart motor needs an adapter plate on the drive end for the second bearing, they are made to bolt to the GC axle, where the second bearing is located normally. The GC axle is geared for slow speed with short tires, so to get city or highway speeds, modifications are required. But the motors and controllers are relatively cheap.
The Following User Says Thank You to CFECO For This Useful Post:
jumper (04-28-2014)
