As I mentioned in
http://ecomodder.com/forum/showthrea...tml#post421474, when I hammered the smaller socket onto the nut, I ended up with a small crack in the manifold, and I put JB Weld on it to see if I still had a problem. [Edit: I swear there was a crack, but after the JB Weld melted off, I took it to a welder, and he could not find a crack.]
I do. I did not drive the car until today, less than a mile each way to Church, there was a burning smell, and when I made a visit just now, my car was hissing when I got back to it. I already pulled the manifold to replace the oil pan, so I can do that easily. The place that sold me the pan also has a manifold, but they want $140 for it. That is cool, I can purchase this for $46.98
off of eBay with free shipping.
I cannot help but notice that it does not have a catalytic converter... it sure is pretty, though!
I will be looking for a local welder and trying to figure out how to remove JB-Weld. That has to be easy, right?
The guy that made a visit with me told me that I was burning something and that it was electrical because my instrument panel lights pulsed. I had smelled the burning, that was definitely new. Finally, when I went to leave, my car was hissing.
When I was trying to fix the stuck nut I went to remove a bolt to be able to adjust the radiator in order to move the exhaust manifold. I learned that I chose a bolt that was not for mounting, but maintained a seal. I quickly had antifreeze spraying and somehow I have broken the seal, even though I never removed the bolt.
Hopefully a welder can fix the manifold, if I need to remove it I can do that easily, but I do not look forward to troubleshooting the electrical problem. How in the world do I fix the radiator leak?! He was insisting that it was my AC system, but the fluid was definitely green.
Oh boy...
