Thread: Tires
Old 04-28-2014, 07:10 AM   #10 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by PAFirefighter11 View Post
I'm looking to purchase 2 tires for my TDI. The wheels are 16x6.5". What size would one recommend? I'm just looking for an inexpensive tire that's going to last a little bit. Current size is 205/55R16. Thanks!
Try to fit the biggest tire you can. There is a small, but significant improvement in RR - all other things being equal.
As a general rule, there is room to go up 2 sizes - in your case, that would be from 205/55R16 to 205/65R16 or 215/60R16, but you will need to check for clearance - and this might require some outside help as the worst case is when the suspension is completely collapsed and the steering wheel completely turned.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
mcrews (04-28-2014)
