Old 04-28-2014, 12:25 PM   #28 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
A friend said that it is cheaper to have a shop change your oil, then they are liable for stripping the bolt, but what are the chances that a shop did this and did not tell the previous owner?
If you've been going to the same shop for a long time and they know they're the only ones who have been touching it, then most likely. If it's a good shop. And if they don't think they can convince you that "It's a common problem with those pans, I'm surprised yours lasted so long."
Originally Posted by vskid3 View Post
Even if a shop discovered the stripped threads, they probably would have done their best to hide it.
If the shop knows they've done it over time, they know they're the ones that are going to have to deal with it next time. If the shop discovers it, they'll tell you for sure- it beats those stripped threads being blamed on them a few months from now. If they discover it and don't tell you, then they might own a little bit of it. But they're not the ones who created the problem over time, so they've got no reason to hide it.
Transmission type Efficiency
