Originally Posted by tony_2018
JDM cel codes are not the same as usdm so you better double check that.
So wait.....how do you know the cel is for an o2 sensor if you didn't check?
He can still use the service connector jump to retrieve the trouble codes from the JDM ecu. But you are correct an OBD2 scanner tool will not read anything or clear any codes if you hook it up to the JDM ECU as they do not use the same OBD2 protocol.
