Old 04-29-2014, 08:21 AM   #2 (permalink)
redneck
I would like to see is a load test (amps) along with the voltage, instead of just a voltage test.
Capacity: 6000mAh
Size: 139 x 75 x 15mm
Weight: 7 Ounces
Output 1: 12V (150-350A).
Output 2: USB 5V 2.1A
Minimum Cycles: 500+
The (150-350A) variance is quite large.
Battery Cold Cranking Amps (CCA) for a gas motor is usually figured at 1 CCA per cu. inch. and diesels at 2 CCA per cu. inch of displacement. With more being better.
This "Jumpr" would probably work under ideal conditions.
How many tries you get at it if it doesn't start the first time though is another question...
