Originally Posted by P-hack
I like the celllogs, they have a lot of features and $16 for 8 cells is pretty good (plus you get a little voltage display and alarm for each cell), and you don't *really* need an arduino in the loop, but getting it to shut off your charger or controller will take a tiny bit of research.
Do you know if there's a voltage meter that can support more cells? 18?
Also, why again wont miniBMS work? Each cell is 3.8v nominal. 4.2v max.
