Old 04-29-2014, 06:42 PM   #64 (permalink)
aerohead
notchback/Beetle
It seems that the VG is intended for the notchback in which separated flow fails to reattach onto the boot,yielding a squareback wake.
The Mitsubishi Lancer suffered from this as well as a Honda Accord.
Successful VGs were sized and spaced with critical dimensions specific to these vehicles.
The Beetle has no rear structure for which to enable reattachment.
In free flight,there exists an axi-symmetrical flow field which provides a jet pumping action behind bluff bodies,which attempts to pump air into the turbulent wake.
In ground proximity there exists no axi-symmetric flow field,and no jet pumping action.
While VGs might reduce the effective wake of a cargo plane,they have been shown during wind tunnel investigations to offer no gain within ground proximity,as well as many other aeronautical technologies.
Hucho says they're a dead end for ground vehicles.(unless there's a structure behind the separation point)
------------------------------------------------------------------------- Ernie Roger's Beetle wing provides a structure in which the longitudinal vortice pair can be burst,and a locked-vortex can be captured,allowing the outer flow a 'surface' to ricochet off.
