04-29-2014, 11:41 PM
#63 (permalink)
Originally Posted by P-hack
the celllogs have an output signal when any cells are too low or high. what model number/make charger do you have, id like to see what bms hooks it has.
The charger I'm looking at is:
1500W 1.5kW 12V, 24V, 36V, 48V, 60V, 72V Output 1500W 1.5kW LiFePO4 Li-Po Lithium Battery Charger 1500W 1.5kW Lead-Acid Battery Charger 1500
OR
900W 12V, 24V, 36V, 48V, 60V, 72V Output 900W LiFePO4 Li-Po Lithium Battery Charger 900W Lead-Acid Battery Charger 900W LiMn2O4 Battery Char
OR
9V 12V 24V 30V 48V 60V 72V 96V 120V 144V 1200W 1.2kW Lithium LiFePO4 LiFeyPO4 Li-ion LiPo Li-Mn Lead-Acid AGM GEL Silicon Battery Charger
I was looking at the Elcon PFC 1500 or 2500 which have cut-offs for charging. But those are pricey, unless I can find them for a reasonable price. All of these have cut-offs for charging. So is a BMS really required? Or do you guy recommend the BMS to monitor as I ride?
