Old 04-30-2014, 10:59 AM   #271 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by samwichse View Post
How are you isolating the aluminum from the steel to prevent galvanic corrosion of those screws?
IMHO I would use ECK
LINK:
Powerbrace Corrosion Kontrol
This is what "Peter Belt" and "Freight Liner" have been using from the factory for the last 20 some years.
I just attended a class where we are seeing this problem once again with some of the new cars that are using aluminum parts.
Ford has had a ton of problems on their Expedition aluminum hatch where the trim around the window makes contact. The factory sealant was not good enough to prevent this problem.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
aerohead (04-30-2014)
