Originally Posted by cbaber
No EGR? BTW, the D15B 3 stages run the 1-wire o2 sensor, the 4-wire is a heated O2 sensor. It will work if it's wired correctly, the difference is the heating element of the 4-wire and running the P2J-003 it's probably not being utilized unless the heating is not ECU controlled.
It is possible to use the d16y8 intake manifold, from what i was told the p2j ecu does not throw a code, annd i dont see a cel code in the list either.
