Old 04-30-2014, 11:30 PM   #220 (permalink)
TheTestPilot
ok , I now see your problem ,so do you want to use the mpGuino ,as the measuring device ,or you want a voltage output vs flow type sensor & read it with something else.
My Idea , was the flow sensor could be connected to The MPGuino without messing with the standard code .
